It is currently Fri Jul 18, 2025 7:34 am
PostPosted: Thu Oct 08, 2020 4:42 pm
First name: paul
Last Name: staples
City: Hull
State: east yorkshire
Zip/Postal Code: HU94QF
Country: United Kingdom
how to shine/polish a guitar table after sanding with 1000grit paper?
I just dropped some black super glue on the table of my PRS SE, rubbing alcohol didn't even touch it! Neither did 2500 grit paper so I used 1000 grit paper which removed the glue but has left the surface dull/rough/matt, and the shine has gone!
Is there a way to restore the shine without clear coating the whole thing?
I tried some D'Addario PW-PL-02S Liquid Carnauba with a microfibre cloth without much success, but I only did it briefly!
many thanks!
drugstoredir2014.com
PostPosted: Thu Oct 08, 2020 5:07 pm
City: Tyler
Go back to your 2500 grit and work the area. You may need to use some interim grits. Then work it with rubbing compound then polishing compound
These users thanked the author Glen H for the post: the_doc735 (Fri Oct 09, 2020 6:21 pm)
PostPosted: Thu Oct 08, 2020 6:12 pm
First name: Freeman
Last Name: Keller
What Glen says. Go back up the grits from 1000 - 1200, 1500, 2000 and your 2500 (wet). Then polish with a good compound (I use Meguiers #2 and 3) without wax or silicon.
These users thanked the author Freeman for the post: the_doc735 (Fri Oct 09, 2020 6:21 pm)
PostPosted: Sun Oct 11, 2020 11:11 am
First name: paul
Last Name: staples
City: Hull
I'm getting these:
https://www.ebay.co.uk/itm/K2-GOLD-LUSTER-Q5-FINE-CUT-Compound-Polishing-Car-Paint-Acrylic-NO-SWIRLS-Gloss/162466877160?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
https://www.premiumhobbies.co.uk/polish-wax/foam-polishing-pad-kit
PostPosted: Sun Oct 11, 2020 5:36 pm
That is a very fine compound and might not be enough to get out 1000 grit, or finer, scratches. You might want to start with a more aggressive cutting compound.
These users thanked the author Barry Daniels for the post: the_doc735 (Mon Oct 12, 2020 2:54 pm)
PostPosted: Tue Oct 13, 2020 8:55 am
First name: paul
Last Name: staples
City: Hull
What would you suggest please?
thanks!
PostPosted: Tue Oct 13, 2020 9:12 am
There are a lot of compounds that would work, but this is my preference:
https://www.amazon.co.uk/Meguiars-Mirror-Glaze-Ultra-Cut-Compound/dp/B01LRHDOUC/ref=sr_1_1?dchild=1&keywords=meguiars+105&qid=1602598287&quartzVehicle=106-1339&replacementKeywords=meguiars&sr=8-1
These users thanked the author Barry Daniels for the post: the_doc735 (Wed Oct 14, 2020 4:07 am)
PostPosted: Thu Oct 22, 2020 5:17 am
First name: paul
Last Name: staples
City: Hull
I used 1500, 2000, 2500 papers and these:
https://www.ebay.co.uk/itm/K2-GOLD-LUST ... 2749.l2649
https://www.premiumhobbies.co.uk/polish ... ng-pad-kit
It worked very well!
Many thanks for all your guidance, much appreciated to everybody here.
